Homemade Bio-Oil
Ahmed
Engine Puncher
Toronto; ON, Canada
Listen up folks,
I found a recipe for some good engine oil that you can make at oil with cheap supplies. It should let your engine run smoother and save fuel. The recipe is as followed.
  • 68%-90% Canola Oil
  • 5%-30% Castor Oil
  • 3%-8% Carnuba wax
I got the recipe from US patent 5888947. Good luck cooking it up! :thumbsup:
P.S. I couldn't find the instruction on how to make the oil so you'll have to experiment. :cornut:
Interesting, to be sure.
But I think I value my engines just a wee bit too much to rely on a bunch o' fixin's from the Wal-Mart, when I can safely bet that the folks at Quaker State, Valvoline, Castrol, and Mobil 1, have all but perfected it for me...
Cooking? Given the wax content, I'd say it's a simple matter of heating it to melt the wax, and blending until homogeneous.
Ahmed
Engine Puncher
Toronto; ON, Canada
Foor school and for curiosity. There is a science project coming up so I thought of building a propane-powered, 6HP, veg. oil lubed., 100kph+ microcar. Sounds weird but the 100kph can be achieved by changing out gears on a lawn tractor transaxle. And the veg oil will keep the engine cooler at those speeds.
It's too bad a Yanmar L-100 style Diesel industrial engine (likely) is not within your budget. Think of all the "tree-hugging" point you could earn with your project not only being veg-lubed, but veg-powered, too!
Have you got your tractor tranny picked out yet?
Ahmed
Engine Puncher
Toronto; ON, Canada
A Perkins 402C is a REAL bad boy. But if someone wants to use it with a lawn tractor transaxle or centrifugal clutch they'll need an adapter to bolt on to the flywheel.
