HM100 intake conversion?
carter
I would like to start using some high-flow filters on my HM100 equipped kart, problem is I can't find an adapter for the things anywhere. Is this something I'd have to make or am I just overlooking some really obvious sources?
What does the intake look like on the motor? Pic.
For the most part you can make intake for anything, just are you equipped to make one, shop/tools/welder ect.
carter
http://i39.tinypic.com/f9leli.jpg
Thats what the current intake setup looks like, the two phillips head screws are the only things holding the plate on so the plate can be easily removed.
Looks easy enough, (need a better zoomed out pic(s), for me to say).
If there is just the two screws that hold the mounting plate on, how does the filter element attach and stay on?
On the honda and clones, there is a long bolt and wing nut w/washer that holds the filter on.
Are you going to use a particular type or just modify your existing setup w/ the factory one.
carter
measured everything twice, made sure to get the right filter, thanks mate.
carter
Got the air filter and adapter in today, stuck em on and wow did it make a huge difference. I'm pretty convinced that the old airbox was choking the thing to death because after adding the new filter I haven't noticed any issues but I have noticed a ton of torque increase. next comes the exhaust pipe, thanks guys.
Which is exactly why when folks come on here looking for performance tips, the first thing we tell 'em about is airflow! After swapping exhausts, be sure to check your mixture, it may end up lean.
carter
I forgot how to check mixture, don't ya pull the plug after running her up tos peed and check for black, tan, or white? I'm just psyched to have enough torque to top this thing out.
Clean and reinstall the plug. Once up to operating temp, go for a long, full-throttle pass. With it still wide open, shut it down and yank the plug again. Oughta be a tan to chocolate brown on the ceramic insulator close the tip. White or bone white are too lean, dark brown/black is too rich.
carter
tis what I thought then, The pipe is getting ordered next friday as tat is next payday, I'll update you then.
