Hilliard Exreme Clutch help
scarletvw
Minnesota
I have my kart and it has a Hilliard Extreme Duty clutch. It works fine right now other then it dings when idling. I took the clutch off and looked it over. The "teeth" on the sprocket are broken, not the teeth that drive the chain but about half of the teeth that hold it onto the drum. Its not the whole thing, just about half of them with the tips broken off so that the drum has a little bit of free play and thus dings like a bell.
Should I go and buy a whole new clutch, or should I buy a new sprocket, possibly a 13 or 14 tooth so that I get better top end. Or just use it till it breaks completely and then deal with it?
Need some suggestions. Also note that I don't have a ton of cash to throw into the cart and the wife will kill me if I spend a bunch.
If that's the biggest problem with the clutch, then it's not a big problem. No reason to buy a new one. You could buy a new sprocket, or worst case, weld the bad one to the drum.
r_chez_08
Should be in the shop...
Cornwall, UK
Should the rest of the clutch be in good working order, then just get the new sprocket.
Please answer ALL of the following, then I can help regarding gearing-
What engine do you have?
What diameter rear tires do you have?
Approx weight of kart and driver?
Terrain the kart is used on?
Number of teeth on any other sprockets on the kart (jackshaft or axle).
scarletvw
Minnesota
I thought about welding it, worst that happens is I have to buy a new clutch instead of a sprocket. If I buy a new clutch I get everything for only double the price of just the sprocket too so everything would be new.
scarletvw
Minnesota
And I will get that info when I have a chance to measure. The only ones I know off the top of my head are:
-Predator 212cc
-Tires are 4.10 x 3.5 x 5
-I weigh 200 and the kart is ???
-Short/medium grass and pavement
-Clutch is 12 teeth 35 chain and axle is unknown to me until I count
If a new sprocket is half the price of a new clutch, I think I'd just weld it. You don't have to run a full bead and risk warpage, just a few good tacks. Be sure to take the drum off and remove the bushing first.
anderkart
Surprise Arizona USA
Maybe your drum/drive gear was defective and you could get replacement parts for free...
You could try contacting Hilliard and ask:
The Hilliard Corporation
100 West Fourth Street
Elmira, NY 14902-1504
Tel.: 607-733-7121
FAX: 607-733-0928
hilliard@hilliardcorp.com
scarletvw
Minnesota
-Predator 212cc
I counted the rear teeth and its a 60 tooth. I also GPS'd it and the first run was 47mph and the second was 41mph. That speed is with the govoner untouched but the throttle stop bypassed. I also emailed Hilliard with a pic, well see what they say.
