Hi, been awhile. Id on this?
dman
Somewhere between Jacksonville NC and Wilmington N
I have run across this three wheeler truckster and I can't seem to find what it is. All I know is that it has an onon performer 20 engine that at least needs the carb cleaned, and some shoddy fabrication work. Would anyone know what it is?
well I can see the MFG name on the plate... (you cut it off so we can't read ...)
but you know the name and the model number..
and frankly I'm a bit curious, why you need us to read the plate you 'mostly' provided
ps to me it looks to be an EZ-Go of sorts
[EDIT]
waaaaait.. that cutoff name on the plate...
JACOBSEN ??
JACOBSEN ??
The plate is in a bad spot and partly painted over the people I asked on Reddit found it to be an ez go utility and with where the name plate is older than 76 buy i cant tell how old.
Nono, the plate is in an okay spot to take a picture of you just cut something important off ;)...
and it DOES say Jacobsen, so people on reddit either didn't have that plate pic to go by,
or just suck at reading/checking ;)
it says JACOBSEN TEXTRON to be precise so it's past 1975 (when Textron bought Jacobsen)
How I know..
well:
looks familiar?
See, to me too.
and yes a slightly different model obviously.. still the same plate manufacturer etc..
soo Jacobsen 2015 (model, not year!)
Just guessing here,
but chances are the MFG Code is plant/week/year
so I'm guessing 13th week (april) in 1995
since if it'd be Vin-coded year instead.. it'd be from 1987 (H)
