element10554
Is it possible to weld 1/4 steel with this welder?
Being able to one day convert to MIG would be nice, but isn't needed for kart building. If it were me though, I wouldn't upgrade a HF machine to MIG. I would rather get a used, brand name welder with a higher duty cycle.
What about a spool gun? Those are pretty easy to work with. We have them at school and both tanks are hooked up to the welder. If you want aluminum, you open the argon tank, grab the spool gun, tap the trigger and it will engage the last settings from aluminum, you dial it in and go.
is there any way to gasless weld aluminum? or do you always need argon?
I'm pretty sure aluminum is 100% argon, because mild steel is 75 CO2, 25 Ar (what I've used), and stainless is a tri mix of CO2, Ar, and Helium, IIRC.
EDIT: http://www.ehow.com/way_5299605_gas-use-mig-welding.html
