HF 6.5 is acting weired.
firekiller52
Flat Head Kinda Guy
nj
iv always run 10w30 pro honda oil of 10w40 napa without any issues, any oil will work , but what you alredy have is the best there is
anderkart
Surprise Arizona USA
ummm. problem solved? i just went outside and i tried every thing. and as i was getting every thing together to take it back i went to turn off the fuel then i noticed it moved real smooth.(wich it hasn't been doing)then i move it back open and choke it and pull and it fired right up. took the choke off and it ran fine and when i throttled it up it wasnt surgey any more.
i assume it wasn't getting fuel? but when i cleaned the carb bowl yesterday there was plenty of fuel in it.
what do you think happend?
I'm not sure but I like transparent fuel line:--> http://www.out2win.com/catalog/fuelline.html
so I can always tell at a glance if fuel is flowing or not... ;)
B man
Tecumseh FTW!
Oliver springs,Tn
ok another problem. well i notice today the was fuel on the bowl of the carb. i cranked it up and i noticed it seemed to come from around the top of the bowl.
any ideas?
