Help
Shergernetic
Shergernetic
Kansas city Kansas
Hi guys I just got a new mig welder and it says 320volt so I was just wondering if I can use the 110volt on it and will it still run right here's a picture
And also do they have a spool gun for it
I got this at harbor fright tools
redsox985
PA
320v is the output, I believe. Use whatever type of outlet the welder's plug fits in to. Either a 110v common wall outlet or a 220v outlet that would be behind a dryer, oven, or in the garage.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
He reversed the 3 & the 2; this welder would put out more like 20v. 120v and 240v work differently, you cant used 120 with this welder.
Also, there are no spoolguns made for this welder
If you do not have the appropriate power outlet in your home or shop, you need to either have a qualified electrician install one, or exchange the machine for a 120v unit.
