Help with my kart engine setup
Oklahomajoe
Me and a few buddies have all decided we want to learn more about building go karts and working with small engines and so we have devised a group contest and I am hoping to get a little help. We are all 3 each buying a 212 cc predator engine and building a go kart. We each have a max budget of $300 after the engine. I weigh 250 and I am about 30 lbs heavier than one of the guys and 45 lbs heavier than the other guy. I know this puts me at a major disadvantage but I still want to give it a shot. In the contest we have to drive 100 yards straight 70 yards to the right then back to the start making a triangle. It will be racing in a parking lot.
So here are my questions.
1. Being so heavy I was thinking a torque converter may be the best way to get off the start quicker and still have a good top speed. Rather than using a centrifugal clutch which will have some trouble getting my extra weight going. Is this a correct assumption.
2. I was thinking slick tires with 11" in the back and 7" in the front. Is this about right?
3. What size recommended sprocket and gear do you recommend with my weight and race track layout? I am thinking that acceleration is probably a little more valuable in this short distance race than top speed but am open to suggestions?
4. My plan is to spend the majority of my budget on the torque converter and bearing, tires, gears and try and salvage the rest of the stuff. Is there anything else that you would recommend I buy new.
5. I wasn't planning on adding a nice flywheel unless that will give me a lot of extra power since they are like $100. Is that right?
I appreciate any help you guys can give. Thank
Welcome to the forum!
1. A TC would probably give you a bit of an advantage over a cent clutch.
2. Tyres look good.
3. With a TC you can always gear a little higher than a cent clutch. I would probably recommend a 5:1 gear ratio. If you have a 10T TC sprocket, you will then need a 50T axle sprocket.
4. Not off th top of my head
5. A new flywheel is not going to help you at all. Billet flywheels are only bought when stock internals have been altered and the governor removed. Stock flywheels spinning at the higher RPM's might fail (according to some people). It does nothing for speed and performance though
Wait up, is outside help considered cheating?
Correct, you would be better off with a torque converter, but there goes at least half of your budget.
As you're talking about replacing the flywheel, I'll assume engine mods are allowed so, hi flow air filter & exhaust, remove the governor...
I'm confused on one thing though: you start off with an engine & a budget of $300 for everything else; does this include a frame?
Oklahomajoe
Thanks for the reply guys. I am allowed to get help and I am allowed to make any engine mods I want. I was thinking about removing the governor but didn't feel like it would be safe without replacing the flywheel.
I am really open to making any changes I can that will give me the most bang for my buck.
As far as the frame I am purchasing one used for like 60 bucks that is in pretty good condition that I will modify.
souperman000
Westlake Village, CA
In short, removing the governor from a new engine shouldn't cause any damage; the valves will be bouncing before it gets fast enough to damage the flywheel.
r_chez_08
Should be in the shop...
Cornwall, UK
Personally I would not recommend a torque converter, instead spend that money on your engine.
Imo when you upgrade the valve springs you should upgrade your flywheel and rod.
Just keep the stock springs and the revs below 5500
