Help with clutch after crankshaft replacement on predator 212
JimD
Naperville, IL
Mystery solved you have a 16mm shaft. You aren't the first to use the magic hammer to get it on. Getting it off is going to be the ***** and most likely the drum no longer free spins on the sleeve but it is a lesson learned and you are wiser for it, we hope.
GEEFYVEN9NE
idk what you mean by the drum no longer free spinning but if you mean like the clutch itself can spin without the engine on, it can still spin its just really put on there lmao
Drum and other parts:
I need a better exploded parts diagram.
Edited to add: Thanks, Jim. Feel free to use it, I just massaged it a little and turned it into an image
JimD
Naperville, IL
Hellion , you certain do nice work and did a great job on the logo. Now if you could just get this to print out I would appreciate it. The china copy is just like this.
  • Six Shoe Clutch.pdf
