Help with adjusting Up-Draft Carb
manco36
I have an 8HP Briggs that has one of the up-draft type carbs on it. I had to take it apart and clean it because it got swamped with motor oil. Everything is in perfect condition. I can start the engine with starter fluid and it will run fine for a quick spin up the street. When I let off the gas it cuts off. A friend of mine was over and we were playing with the Idle screws and now I think it's all out of wack. If I take the carb off, clean it, put it back together and use starter fluid to start it, it will idle fine for about 2 or 3 mins before it cuts off. But if I start palying with the accelerator it will cut off and I'll have to use starter fluid to start it again. If I choke it, gas swamps the carb and leaks out the bottom. I know the float doesn't have any leaks I know the jets are clean and the needle is installed correctly (used a diagram to be sure.) If I take the carb off and hold it upside down and try blowing into the fuel line, it wont let me blow into it. So I know the float isn't stuck. It has to be something with the idle screws being out of adjustment.
I tried following the directions on the Briggs site for adjusting them but that set of directions was for a regular bowl type of carb. I'm not sure which is the idle and the high speed mixture and all that stuff. It has a screw where the jets go in, another screw on the opposite side (which I "think" is the high speed mixture) and of course the idle screw where I can adjust the idle RPM's. But I can't get them to work. I tried screwing both in and backing them out 1 1/2 and starting it but it won't hold an idle if I do that. I tried doing the same backing both screws out to 2 and 2 1/2 full turns as well. But it still wouldn't hold an idle.
Does anyone have a picture of an up-draft carb that they could label which screw is what and how to adjust this thing? I'm dying to get this thing running but I've failed at everything I've tried.
Thanks so much!
zbuck
Ft. Wayne, IN
:wai: That carb. is a small two piece flow jet carb. Cutting off after 2/3 min's it is not pulling fuel into the engine. When you put it back together did you get the gasket between the to halves in the correct position, as it will fit to different ways. Check and make sure that you have the gasket not covering the air bleed hole in the bottom halve of the carb. Any air leak, wether it be where the carb. bolts to the intake or the gasket between the to halves. Will cause your problem. Idle fuel mixture screw top of carb., main fuel mixture screw bottom of carb. Both 1 1/2 turns initial adjustment. turn the idle screw down a little for more rpm's at idle. Did you pull the main jet out and clean all the holes? Also the correct way to take that carb apart, is pull the main jet 1st and then the emulsion tube re-install both after putting the two halves back togehter. The reason being is that the emulsion tube goes in the top halve a tad and it will bend if not taken out before parting the two halves. Also read the site landuse suggested.
solomon
ca
What about the tank? Any water in the fuel any garbage? What about a fuel filter, do you even have one? How did motor oil get in the carburetor?
