Heat shield or no heat shield?
Kleyny
Brisbane Australia
Just playing around with my gx 200 and had a thought do I really need the heat shield under my barrel? I understand that it directs air from the fan on a stationary engine but since its on a go kart I'm wondering if it is doing more harm than good.
I have had this kart heat up and slow down before when running flat out for 30minutes or so in and out of softish sand. Hence all the new mods and questions.
Thanks
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
You need the engine tins.
Especially if you have already had an overheat issue.
Staff Murderator
Change your oil. Change it early and often. Dirty oil loses its cooling facility.
Make sure you are topped up on oil too. Should be checked before running every single time.
Kleyny
Brisbane Australia
I must admit I did put cheaper oil in it when I first got it going.
Now I know how addictive it is I have purchased quality oil.
Heat Shield Shmeat Shield.
If it makes you sleep better at night, keep it on.
It won't hurt anything.
Kleyny
Brisbane Australia
Well I just put it back on.
When I put the engine back in the kart I ll see how much air gets forced past the cooling fins when shes running.
In the part of Aus I live temps regularly hit 35 deg/ 95 Fahrenheit in summer so I need all the cooling i can get.
