header?
slideways
If you only weigh 74lbs a clone in stock trim should move your *** plenty well.... i wouldnt worry much about more mods.
kendelrk
redneck engineer
westland michigan
I'm a speed demon. I get it from my father. And trust me it does, I get a thrill from high speeds and whatever I can do to get more speed I'll do. Except I'm broke
B.M.800
TheBeal.
Central PA
About 1hp or so gain. Its noticeable in most cases. The motor pulls harder through the midrange area and is alot smoother and responsive.
For most people this is all they need and they overbuild their motors. Or they start building them and give up because they can't finish them or get them to work right afterwards.
Is that with removing the gov too?
Here are some good "budget" performance tips. When it comes to the high HP stuff remember-
"Speed is a matter of money. How fast can you afford to go?"
slideways
Either way. I have a header/intake/jet on a governed minibike that has the throttle screw backed out. According to my tach it runs around 4200rpm at peak if you are on it accelerating.
The same is true if you take the governor out. The valves will float around 5500rpm and hopefully you don't break the rod or have a flywheel magnet blow off.
Having dyno numbers and charts really shows how dumb it is to just go after rpm like so many of these kids on here do. They think just because they can go 5000rpm instead of 3800 they're kart is so much faster. Truth is that the clone motor starts to LOSE power dramatically after about 3400rpm so turning more rpm is really just making the wheels go faster and wearing out the rest of the motor. You could do better just changing the gearing and leaving the motor alone otherwise.
B.M.800
TheBeal.
Central PA
What about genuine Honda? I was thinking about a header and air cleaner... I suppose even if for a minuscule increase in power, but the increase would be noticeable?
oscaryu1
Last time I checked, a faster turning wheel usually means a faster kart LoL.
slideways
Right.. what i'm saying is do it with gear ratio.. not at the expense of your motor. In racing you want to be in the torque peak of your motor as long as possible and at the right time.
It doesn't matter if its a genuine honda or not.. the clone is the same thing. This is general engine theory which means it will benefit most any engine. An engine is a big air pump. Any time you can get more air in and do more with it.. you will get more power out.
B.M.800
TheBeal.
Central PA
Errr, sorry Im not sure I understand what your saying...
You say if you want more speed then gear it for more speed?
Thanks.
robbie
Osceola, Missouri
Thanks.
That's what he's saying. But there's one thing missing from that piece of advice, which is that a go kart has only one gear, unlike a car with a multi speed transmission.
Gearing a stock motor for speed is going to hurt your acceleration. Gearing it for acceleration, plus increasing the power, is going to give you better acceleration and top speed.
In other words, just making your wheels go faster will indeed give you a higher speed.
kendelrk
redneck engineer
westland michigan
true but you have to have a good ratio, my ration is 4:1 and i have great speed of up to 45 mph and some pretty good accleration
redsox985
PA
Is that on a kart or minibike? Does your clutch drum glow cherry red? Do you have a TC? 4:1 will not work in most cases although it will yield speed. If you want speed from cent. clutch, be prepared to have a slower take off. If you want take off, you're going to have to sacrifice top speed.
And a 4:1 ratioN? No wonder kids are starving all around the world. You're eating everything. :p
kendelrk
redneck engineer
westland michigan
Minibike, and no holds up quite well docent glow red no torque converter direct an it has good acceleration look at the video
redsox985
PA
I bet that's because it's on a minibike which is considerably lighter than a kart.
