head swap for gx200
smashpie
hey guys first post up here.
just wondering what the best mod would be for a head swap.
i hear a lot about swapping for the gx160 but can i get away with using the 120?
keeping in mind direct swap with little to no additional mods.
the block i am running is a gx200 clone.
Bluethunder3320
ive heard gx160 head on the gx200 means more compression (what your trying to do) i havent heard of using a 120 head and i could imagine its a smaller size block with smaller valves and ports so theres a power loss.... even if it does bolt up.
id just go with a gx160 head
EDIT: oh and welcome to the forums!
smashpie
thanks .
ill keep doing research but im hoping that the 120 will fit as long as the head lines up with the block ill be happy then getting it to work right. :S. with the required mods yes valvs are smaller so i might have to think about opening up a little
but from what little information is out there on head swaps im kind of in the dark.
and higher compression will put more stress on the rod and head so i might swap that out. how much power can a clone motor handle any ideas? its the one made by powerfist lol
kendelrk
redneck engineer
westland michigan
the main problem with the gx120 head is that the valves might hit the head and bend which idint good, and there all lifan, what mods you do to it, depends on what you have done to it, ive seen them up to maybe 15-17 hp. so its all what have you done to it, also in a sticky here somewhere, i seen a write up by oscrau1 it was a briggs guide but did claim that the power gained from the swap is lost and it decreases power, dont know if the same is true, but it might be
kendelrk
redneck engineer
westland michigan
the valves come up to clear the combustion chamber, when you pull the head, the piston and valves are still inside, the valves come up (intake, exaughst) so far in the stock configuration they come up so far, now when you make the area smaller, the valves and piston also, might come up and hit the head, causing bent valves and a messed up piston
smashpie
lol no raging on ppl i knew what he means. so the gx200 with a gx120 head wont work cause of clearance issues. wouldnt be a hard fix unless that is to get the clearance on the gx120 valves is the same clearance required for the gx160 then yes ill go for 160 but even if its smaller with out interfeering then i hope to not see power loss.
kendelrk
redneck engineer
westland michigan
lol around here were always doing that, its normal youll get used to it on the forum, you want to see some of that look at our intake/exaughst switch, thats where it gets bad but sounds good, ive heard of it as a big performance mod, but you might loose power, we dont really dyno thesse things, diffrent conditions,
smashpie
been searching the net for this swap and no one has done it. :(
im sure the length of the valves are not as long as the length of the 160 or i am wrong with that one?
kind of looking towards...
more compression with better fuel added. just more power with an unusual setup.
too bad they dont make variable valve timing
r97
Measure twice cut once
Massachusetts, USA
Sounds like your describing a flat head engine. The GX200 is an OHV engine. Also note that it would require a very weird shaped head to have interference with the piston and the head without increasing the stroke no?
I would go with a GX160 head. I have a feeling the people who put $1k into these engines would figure out which head works best. Also as blue mentioned, the bolt pattern is probably different and the valves are likely smaller.
smashpie
yeah i read up on that site lol. valvetiming on that key but i was hoping something like vtec lmao. where a pin props slightly higher cam profile when a specific rpm is reached lol
smashpie
looks like the gx160 head is going to be chosen . what kind of gains am i looking at ?
.5hp to 1hp or a little more
DustinWolfe
Meridian, Idaho
what you gain in compression your losing in flow. are you just looking for a little more power or do you plan on building something strong. there are better choices for mild power increases
smashpie
just more power for a relatively low budget.
my expectations are 2-3 hp gains on a 200 dollar budget
