Have a question about mounting lifan 6.5 on azusa road rocket.
maq1919
Just ordered the Azusa road rocket from go karts usa. yes I know it's small but ill make it work. I'm planning to mount a lifan 6.5 engine here it is http://www.amazon.com/Lifan-LF168F-...UTF8&qid=1365894439&sr=8-1&keywords=lifan+6.5
Also I already ordered the clutch btw I have nether of these yet but there on the way. Can someone tell me how to put the clutch on what I'll need to mount the engine to the kart. The kart says weldless Just basic tools so that's what i'm counting on. also want to know if the lifan 6.5 will fit the road rocket. thanks
The engine oughta fit fine. Standard mounting hardware (nuts, bolts, washers, etc) are all you need to get the engine on. Mounting the clutch will require you to simply tighten the grub screws (if equipped) or a bolt and washer into the end of the PTO shaft.
spyder1968
New Bedford, MA
they are well made little karts! ( and i do mean LITTLE!) i have built 2 of them. and , as already stated above, the engine simply bolts on! they are pretty simple to assemble!
