hi guys i have a on off switch and want to connect it someway so i can turn on and off the system . its a 24v system i also have a throttle that has a key switch but the way you guys told me to wire it , system stays on even if keys removed or turned off, id rather fox that because its already there and looks nicer ?
Standard procedure is to connect (1) side of the switch to (1) side of your "power" lock plug
…& connect the other side of your switch to the other side of your "power" lock plug.
When the switch is "on" (making contact) your system should be on
...when switched "off" (not making contact) your system should be off
Try your other switch to double check that your system is functioning properly
...because the (2) extra wires on your throttle (when connected this way) should do the same thing.
IIRC when I tested this type throttle, the key switch functioned as expected
(switched the attached circuit on & off)
...but, the meter stayed on. (even when the key was off)
I wasn't impressed with this design because, unless there was a main cut-off switch (& it was used)
...just powering that little meter would be a small but, constant "parasitic" draw on the battery pack.
