Harbor Freight new 224 engine?
jmaack
Kind of looks that way. RBG has a video up of it. Watching it right now. I'm dumb, it is electric start, but it has a momentary switch and not a key switch that we are used to seeing on electric start engines.
ha i found and am watching same one now. pretty cool
just saw key switch.
So pressure lubrication and an oil slinger on the rod. Well that crank needs to be oiled some how. Well, if I can't get the sled running, I know what my next engine will be!
jmaack
id be willing to bet you can tap in to the pressurized tubes and have oil wherever you wanted it internally. might have to bend some small tubing. Still though. very cool. I couldnt look at the pto side the other day. Wish i could have that cover after looking at it screams pressurized oil.
FabnOkie
Oklahoma
yes but it only has the 7 bolt side cover like the 420, unlike the vegas carts 460 or duromax 440 that have the 10bolt side cover and stronger blocks
I don't really think having 3 extra bolts holding a side cover in place will really matter that much. Long as its reinforced properly it should be fine. I doubt the stator will be greater than 3 amps, not overly useful other than charging a battery and maybe running one LED light.
