67dunebuggy
- Messages
- 18
- Reaction score
- 0
Hey guys. Thanks in advance for your help. I have oil leak coming from the cvt cover on my gy6 150cc. The engine is in a gokart. American Sportworks Carbide 7150. I have taken the cover off. Removed the variator and clutch and cleaned everything. The leak is coming from the cover behind the variator. Looks like I need to replace the o-ring.
Is this a straight forward fix? Drain the oil, remove the cover, install new o-ring, put the cover back on and refill with oil? Or is this going to be more in depth. I've search the web and you tube and haven't found anything on how to fix it.
While there are only two bolts that hold it on, there are two other partially threaded holes, but they don't go all the way thru the cover.
Again..thanks...Bill
