gy6 DC conversion questions/comments/opinions
linuxman51
volvo spaz
mont, AL
I hope I'm not beating a dead horse here, if I am, I apologize. I've been googling this particular topic for a few days and most information appears to be a bit disjoint and/or "less" than what I'm looking for.
Cliffs: I'm fuel injecting my buggy, and I wants more amps and watts and more more more.
There are a couple of paths I can take with the electrical system on my buggy, and finding conclusive information has proven to be more difficult than I initially thought with the plethora of results on the ol' google. The 8 pole stator conversion to DC is fairly straight forward it seems, some minor modifications of the stator and a different (trail tech?) rectifier, and off you go. But little has been said of the resulting available amps.
The 11 pole upgraded stator (And apparently the required rectifier and flywheel) is said to be a good upgrade, but then little if anything is mentioned about it's output, just that "it's good". I'd like a little more than a simple "it's good", because I would rather sort this issue out once and move on, and it'd be nice to keep everything inside the engine more or less (however an alternator off a car is a tempting solution as well, if I can determine an effective way to mount one).
So the questions are:
On a dc converted 8 pole, what can I expect in terms of average watts/amps, and
On an 11 pole (dc or "normal", since it's 3phase apparently) what can I expect in terms of average watts/amps, and is there a documented conversion to DC for that guy?
I'm not trying to do a whole lot, but I'd like the system to have enough capacity to not be constantly draining the battery during operation.
the requirements:
fuel pump -> ~5-6 amps (maybe less)
Ignition coil & ignitor -> 2-3 amps (hopefully less)
ecu -> 2-3 amps maybe, probably less.
injector -> ~1 amp.
so I'd need 10-12 amps minimum and maybe 15 max, so even a small alternator would be overkill (but if it's the easiest path...). I've even considered mounting an alternator to the the chassis and running it off the axle instead of the engine, so it can provide help when the buggy is driving, but that may not work out nearly as well as it sounds in my mind :roflol:
For the moment I'm not worried about lights, etc, and I will be fitting a larger battery to the buggy for this as well.
So, TL;DR:
Known amps/watts for a dc converted 8 pole stator configuration?
Known amps/watts for an ac 11 pole stator (and is there a conversion to DC for it)?
Thanks.
