Gx340 a$$istance is required :')
Brad_R
Bristol, UK
Hi
I have a genuine gx340 and it's very weird as it is at the moment.
A few weeks ago I found out I needed to reset the governor as the engine would rev to infinite and back straight away. That made me very nervous about it to the point I can't pull the cord anymore. I've got my dad to start it a few times and after resetting the governor it ran fine. I've just replaced the governor spring and the throttle arm spring and the governor shaft hasn't moved from its position beforehand and it only starts on choke. And now when you take choke off it tries to rev as far as it can again.
I'm desperate for some help now as I'm absolutely ****ting myself with it now lmao
Thanks in advance I guess?
Half-breeder
"Edit" button removed
Sounds like either the springs are attached in the wrong hole(for the springs tension) or the governor spring is not the proper spring... Detailed pics/vid would help narrow the issue.... Maybe.
N plz fill out ur profile!
Please mind your language; as there are a few young kids around, this is a family friendly, G rated forum...
We do have a filter for that kind of language but, aparrently, it doesn't seem to be working...
Half-breeder
The filter worked my end when I posted it. If it didn't censor I would have edited it
It's quite possible that your not getting the 'hint'... in the immortal words of B.B.Thorton... "Y'ought not talk like that... you're just alil boy..." ...'Slingblade'
... and if 'that' dont grab an attention follicle...
Whether or not, being filtered or not... a 'man/woman' can and alotta times are judged merely by the language that he/she, overlooks as 'daily talk'...
The goal is to get as few filtered words on your record... not the other way around...
And again... please fill out your profile.
