GX200/Clone: Worth rebuilding?
keaton85
Snapped the rod on a GX200 clone. I know I can get one from HF for $100 but this motor is in good shape and only needs a crank and rod.
Worth messing with? I stripped it down and everything looks to be in good shape mechanically. I do have to JB weld a small crack in the block from the flywheel rubbing after the crank let go.
First thing you need to ask yourself is why did the crank & rod let go? It's possible you could spend time & money repairing it only to have it let go again...
keaton85
I'm imagining, that use "big kids" got a hold of it and wouldnt give it a break for a few hours haha.
From my reading, I was under the impression that the clone cranks are weak due to the hole that is drilled through them at the rod connection? Or maybe we were just over revving it but I figured the rod would go before the crank.
You lost the rod and crank, and there's ZERO internal damage? You either have a horseshoe in a potentially very uncomfortable location, or you missed something. With regards to the external damage of the flywheel rubbing the block- is it a "crack", or a gouge?
If it were a genuine Honda, I would consider repairing it, but a clone? Dunno. Maybe if there truly is no internal damage. The thing is, with a broken crank and rod, stuff flails around like it's not supposed to, striking things that prefer not to be stricken. Have a closer look.
Under what circumstances was to over-revved? Did you bypass the governor, or remove it completely?
I find it kind of *interesting* that the crankshaft and connecting rod met God, yet the flywheel is still intact. So much for that myth! :D
keaton85
The crank split right next to the rod journal so the motor ran just fine, just a little sloppy haha. The only damage that was done to the rod is the output shaft side of the crank rubbed the rod enough to have side to side play if I reinstalled it. Hence needing another rod.
I can take pictures if anyone cares but really, it only needs a rod and crank. The seals are still in good shape surprisingly!
I really don't know how it happened. the governor wasn't bypassed but maybe someone set it up so there would be a lot more tension on the spring to the governor and that over revved the motor?
Another idea is while using the kart we would fly down the dirt road and slam on the brake to 180 back up the hill. Possibly causing the crank to much stress with the sudden stop? Although I would image in the clutch would retract and freewheel the motor during braking.
Interesting. I don't think the sudden deceleration would be a problem. Also, the clutch won't release until things slow sufficiently. However- it's possible that the hard turns were oil-starving it.
All that said, then perhaps it is worth the effort to rebuild.
r_chez_08
Should be in the shop...
Cornwall, UK
Providing everything else is fine, I would just rebuild the engine. $25 for the parts vs. $125 for a new engine. I know what I would choose... after all, you have already stripped it down.
Ideal oppurtunity for modifications?
For $60 you could have yourself a billet rod. For $20 you could have a flat top piston and rings. For $60 you could have a new safer flywheel.
