GX200 Clone on Ethanol
DennisB
Germany
Hello,
First of all, I'm german and my English is not perfect. This forum is really nice ;)
I want to run my Honda clone engine on pure ethanol. I have drilled out the main jet on the bottom of the carb. The engine starts with choke, but runs too lean in low-idle (after shutting off the choke the engine shuts off). If I open the trottle up to 75% after shutting off the choke, the engine runs fine but when the engine goes back into low-idle it shuts off. I think that I have to adjust the low-idle circuit in the carb, but i don't know how... I turned the screw at the left side of the carb in both directions, but I haven't noticed a change... How can I modify the air/fuel ratio in the low idle circuit?
--Dennis :)
r_chez_08
Should be in the shop...
Cornwall, UK
Welcome :)
You see the black plastic screw? Take that out completely. Then get a flat screwdriver and pop out the black jet underneath it. You then need to drill this out.
DennisB
Germany
Thanks for your responses, I hope that it's ok to post a picture of my carb from the ebay site where I bought the carb ...
Do you mean that I should remove the brass screw under the idle-speed screw ?
There are some more pictures on the Ebay site
The engine is a 6.5 HP Honda Clone from Lifan with removed governor ... Note : Scary fingernails :eek:
Welcome to the form, Dennis. Yes- that brass part is the one you're after. Don't apoplogize for your English- it is better than many who are born English-speaking!
r_chez_08
Cornwall, UK
Sorry yes, the brass jet. Most clone carbs have a plastic jet. Yours is different.
Cheers,
Rob
DennisB
Germany
Okay, I finally screwed out the brass screw (I had a lot to do for school) ... It looks like a nozzle. Is this the nozzle which i have to drill out ? (I mean the small hole which is on the top of the screw in picture 2)
DennisB
Germany
Okay I'll buy some very small drill bits and gonna do it how you said it, one size at a time ;)
DennisB
Germany
It works! :bannana:
I drilled out the idle jet with a 0,5mm drill, but still same problem.
Then I went again to our local home depot and said that I bought the wrong size of bits. They exchanged the product to a 0,8mm drill bit :D
After drilling it out again, it finally worked. The engine runs now without choke, but I need something like "easy start spray" on cold days (that means almost every time in Germany) .
The engine still needs some adjustment because the engine dies if I open the throttle too fast.
Thanks to everyone who helped me. I can now run my engine from ethanol made from these disgusting apples from my grandma's garden...
r_chez_08
Cornwall, UK
Sweet, nice!
Please note that you should go up in much smaller size increments though. 1or2 thou of an inch or .03mm at a time is ok.
Try to get some number drills, #61-#80 in size.
anderkart
Surprise Arizona USA
I'm glad you've got your jetting problem fixed now, but do you realise you need to drain your fuel tank, flush out the fuel-line and carb, and change your oil after every day (or 2) of riding your kart now?
Because the moisture that Ethanol tends to absorb will eventually corrode your carb, and the extremely-rich jetting (thats required) will cause the fuel to wash on down past your piston rings into the crankcase, and this pollute/break-down your motor oil... :thumbsup:
DennisB
Germany
No, I haven't realized it.
Is there a motor oil which doesn't gets polluted/broken down by the ethanol ?
btw, I found a additive, which prevents the ethanol from harming my engine /carb : Safeguard or Sta-Bil.
I'm using regular 15w40 in my engine.
r_chez_08
Cornwall, UK
just make sure you switch off your fuel tap and run the engine till it dies at the end of each use. If you are going to leave the engine for more than a few weeks I would flush the carb through with petrol.
Not trying to be an idiot- But lets be honest- these engines are cheap, and so is a carb. If you find your carb gets gummed up, learn from it, and clean it, and should it be beyond repair (highly unlikely) a new carb is under $20.
I am not sure which oil is best, but I would pop down to a local store and get a few litres of sae 30 or 15w30. Change it every few hours, and check it reguarly.
I have to say- Good on you! Making your own free and "green" energy. Hows it done? I have a load of waste apples in my parents orchard. We have so many that the brused or blemished ones tend to go to waste.
DennisB
Germany
I already bought a new carb for ethanol modification. I still have the stock carb for petrol. Making the fuel is quite simple. The first step is to ferment the apples or something else which contains sugar. I do this by blending the apples, add some water, add some yeast and put the mix into an old tank, bucket, whatever. The container just needs a lid with an airlock, you can buy it in brewing stores or make your own (google). When the fermentation is done (btw its important that the mix dont gets colder than 10°C, because the yeast is inactive under this temp. ) you have to seperate the apple chunks from the alcohol containing liquid. This can be done by pouring the mix into an old towel and pressing it as hard as you can (to get all the liquid out of the chunks). The apple chunks can be composted in your garden (good fertilizer). The next step is a little bit difficult. You have to distill it, which means you need a still. And this is illegal in the U.S, exept if you ask the tbb (www.ttb.gov) for a permit that allows you to produce your own ethanol fuel. The permit is free, but you have to allow the tbb employees to visit you. The most expensive part is the still. If you want to produce high proof ethanol, you can't use a regular still, you need to built (or buy, but even more expensive) a fuel still like the "charles 803" by robert warren (google). I'm building a half scale version of the charles 803 still out of stainles steel. For more information, robert warren's homepage .
DennisB
Germany
I checked my oil today and I think this project failed:toetap05: Changing my oil every hour is too expensive for student like me.
I replaced the modified carb with the stock one and filled the tank with regular gas (and changed the oil) ...
anderkart
Regular automotive motor oil breaks down fast when polluted with methanol, exspecaly with a high moisture content. There's serveral different brands of oils formulated to handle this situation better, but you'd still wanna change those oils quite often too...
More Info here:--> http://www.google.com/search?source...de99d2aacf4e5d&bpcl=38625945&biw=1024&bih=532
Those Safeguard or Sta-Bil additive are probably made to help out a bit, but only when using an Alcohol blended gasoline, not pure Alcohol...
Its fairly easy to check the check for water/moisture in Alcohol, simply shake some in a clear container:
If it gets all milky/cloudy looking, = you've got water in the alcohol.
Or, If it remains 100% clear = no moisture.
From the looks of that oil in that drain pan, I'd say you've got LOTS of water in the Alcohol you've distilled.
_______
Good Idea, You'd probably be waisting more crude oil with all the oil changes, than what would be used to produce the amount of gasoline needed to run a small engine like yours... :thumbsup:
