Well as far as I know that's the vent for the emulsion tube, on the opposite end, there should be a smaller hole (sometimes brass fitted) same side sitting a little lower;
these two regulate the air pressure on the emulsion tube. (or the float chamber itself can't recall)
what would happen? IDK, I guess you'll ruin the mixture and the possibility to set it correctly.
It's designed -as you can see- to not be blocked easily, not even by the gasket;
so that must be intentional.
worst case: you cannot create an air/fuel mixture that's able to feed your engine,
and you render the carb useless.
best case: it's some sort of high-flow shut of valve, that'll pop the vacuum when the engine is revving above a certain rpm (somewhere in the 6000 rpms)
As you can clearly see, it's fed outside behind the gasket to the lower right corner of the flange.
When the engine is running, cover that vent with your thumb to test,
or add some electrical tape if you want to testRIDE with the vent covered.
I don't know, what will happen, either the engine is acting perfectly normal (then it's likely a pop off valve thingy) or the engine will run ugly or even die occasionally (then it's a regulating valve thingy)
*shrugs*
tell us how it goes... you made me curious
How about you not block it? It was put there for a reason.
Here is some photos showing the vent hole passage and where it leads to,look at the little rod that I have installed in the float bowl vent.I have about ten of these carburetors in my shop.
Absolutely!Thanks a lot for the help!![]()
Bowl Vent,which is higher than the main jet discharge nozzle in the venturi,if the floats sticks or the needle and seat leak fuel will flow into the engine through the discharge nozzle into the engine,this happens sometimes and fills the engine full of fuel most certainly with a gravity fed fuel tank.Looks like it could be an overflow in case the float sticks or doesn't seal well. If that's the case, it lets fuel run out onto the ground instead of into the engine which would lead to filling the crankcase with gasoline.
EDIT: It seems a little high up for that though. I guess it's just an air vent to equalize air pressure inside the bowl.
