GX140 Goes once started
deey001
First off Hello to everyone I am new here.
I just bought an old gokart on craigslist and it has a honda gx140. I have no problem starting the gokart up, problem is once started it starts to go. I did my research and thought it was the clutch, but I am able to pull the gokart without the wheel locking or the engine turning over.
I also bought another clutch on amazon and tried installing it today and the gokart behaved the same way with the exception that the chain came off because it was loose.
I don't know where else to look. I tried adjusting the idle screw and that does nothing.
The only other thing I noticed was the plastic screw on the carburetor is broken, but the gokart fires up and goes with no problem.
Any suggestions will be greatly appreciated.
Thanks,
Danny
B_Bimmer
Usually the plastic screw is the idle screw. Adjusting the idle screw should do something unless something is stuck in your linkage or carb. Definitely sounds like an idle issue from what you have said.
deey001
Is there anywhere online that sells only the plastic screw on the carburetor?
Also, there is a spring that's going under the gas tank (i think to the throttle) to a plastic piece on the carburetor that seems worn out.
Also, a side question. Is it worth modding the gx140 with my son, or going and buying a bigger predator and modding that motor?
Thanks again for your help.
Got a small gas engines shop nearby? They might have the part you need and/or can order it for you.
deey001
Thanks Flyinhillbilly!!!
The screw im talking about is on the actual carburetor. not the one on the linkage.
Here are some pictures.
deey001
sorry here's the broken plastic screw
