Guy with Yellow Jacket
btroy
DFW
Hello guys!, thought I would intro myself before posting questions.
Bought an old yellow jacket single seat kart to rebuild, don't have much into it so its going to take some work.
Tore apart the tank and carb and they look toast. Has a 5HP B&S, drained the water(oil) out of the engine so it maybe toast as well.
From looking at price to replace carb and tank I can almost get a Predator 212. Would this be a direct replacement? As in would the clutch and sprocket swap across?
Thanks and look forward to the build and advice.
Troy
Will post some pics once I take some.
Troy
Welcome to the forum!!
The predator should be a direct swap. The mounting holes are the same, and the output shaft is the same diameter on both. You shouldn't have too much of a problem
btroy
DFW
thanks for the welcome,
Got the 212 installed, just need to start ordering new parts.
