Greyhound 6.5 to ???
NewDingo85
So I'm new here and have a quick question. I got a steal of a deal on an older Manco Dingo that was in great shape. It had a Greyhound 6.5 on it that looked fairly new but wouldnt run unless it was choked. I took the carb off and cleaned it real good and drained all the bad gas out. Still did the same thing. The bolt in the bottom of the bowl decided to strip out so now I need a new carb. I'm thinking of just getting a new motor and be done with it. This brings me to my question. I've heard good things about the Predator 212s and know that its a direct swap. Is there a bigger HP motor that I could go with since I'm going to be buying a new one anyway? I don't want to have to modify anything so a direct replacement is what I'm looking for. Any help is much appreciated!
So I should probably just stick with the 212 then huh...
Why mess with something that you know is going to work. If you get a better engine, you are probably going to have more work on your hands than fabricating a new motor mount. The output shaft may be longer or shorter, meaning sprockets don't line up.
You might have a torque converter on it now as well. If you get a larger engine you are probably going to have a 1" diameter output shaft. This will mean you are going to have to buy a new TC. If you have a centrifugal clutch, new ones that fit 1" shafts are over $100. So it will not be just the engine you will be swapping.
It will just be eisier using the 6.5HP. they are good engines, and if geared correctly they will push you around with no problem.
NewDingo85
Ok, thank you for the help. I think ill stick with the 212 since im running a centrifugal clutch and don't want to come out of pocket an extra 100 bones.
Kelly Wood
The Mad Kartist
Salt Lake City Utard
Sorry to hear the thing got stripped. The original problem is simple. Here in Utah at Miller Motorsports, the sealed engine for the 4 stroke classes is the honda GX200. Greyhound, clones, whatever... and they all have the problem from time to time. Only runs when choked...
If you run into that problem again, take a flathead screwdriver and unscrew the jet. It's up inside the same hole that holds the bowl on. There's something in there, blow it out, reassemble... it'll run.
then, put a fuel filter on it.
I love my Greyhound 6.5.
Kelly Wood - Kartrods.com
