greyhound 6.5 hp problem
xvolcomloserboyx
i have a greyhound 6.5 hp gas engine installed on a yerf dog go kart, turns on with first pull but when i put the choke to the open position my go kart takes off and i have to close it back ?
Ok, first, define "open choke position". To me, open choke means the choke is not active (because the carb throat is open & not restricted) so, opening the choke shouldn't make your kart take off.
However, if, by open, you in fact mean closed (as in, the choke is engaged & the throat is closed) the reason it takes off is because the engine RPM is higher which engages the clutch...
If I'm reading this correctly-
1) You close the choke to start the engine
2) After the engine starts, you open the choke, and
3) The kart tries to take off on you- Yes?
This can be indicative of several possible problems. Your idle could be set too high. Your throttle linkage could be binding or misadjusted, not allowing the engine to idle. Your carb could be dirty/ partially clogged/ misadjusted. Your governor could be non functional or out of adjustment. Your chain could be too tight. If you have a CVT, you could have an issue with that, too.
How long as it been doing this? Did something happen that may have caused it? Did it sit dormant for a long period of time?
