tinkerer
I was removing the engine cover in order to remove the governor gear and the cam gear came off with the cover. I aligned the dots together; is this right? Also, should I remove the governor gear pin and silicone the hole shut or will the pin stay in place? Are the valve springs and rods still ok since the cam gear came out?
