Got a 2.5 HP snowblower engine but it doesn't have a throttle! Help!
blackthunder
I purchased a used Toro snowblower (snowmaster 20) for $20 thinking it would be a good engine for the yard kart I want to build for my 4 year old but when I got it running and took all the plastic off I found there is no throttle! Just a choke lever and the govener controlled lever. Is there anything I can do or is this a lost cause?
The engine has a tag on it that says 1585 Tecomseh 7090 and I traced the Toro s/n back to a 1978 model with a 2.5 HP AH520 engine, RPM 4100-4500
Guess I could use the gas tank if nothing else will work on the go kart.
Thanks,
gvfc2
wishing i was living
Tacoma,wa
im thinking the gov. controlled lever is the throttle. just play around with the levers as its running and the one that speeds it up is the throttle. or just replace the carb. but wait for some more people to chime in
r_chez_08
Should be in the shop...
Cornwall, UK
Where does that spring go to from the carb? Straight to the governor?
Since it would be on a child's kart a governing system would be useful, so removal should be avoided if possible.
:iagree: with both posts.
An engine doesn't run off the governor, there must be a throttle butterfly somewhere on the carby. When you find it, put a spring on one side & a cable on the other & you'll have yourself a throttle :D
Thunderbird SC
Western New York
There is a throttle. I have about 8 of these engines. they varry a bit from model to model - type and size of carbs, hp, displacement, ect. The throttle is connected to a arm that attaches to a air vane governor. on the other side of the throttle is a spring connected to the carb bolt/ attachment. pretty basic setup. I'm stalled on my powerwheels gokart project due to cash limits...but it uses the same engines
blackthunder
This would disable the govenor though wouldn't it? I can make it rev up and down using the one butterfly that is on the carburator but it is manipluated by the air vane like you said... isn't it dangerous to disable the govener in this way and manually control the engine?
I will take off the engine cover tonight and take more pics and post them.
Thanks,
sexyvicta
piston port tecumsehs rule
rip off all the governer stuff and hook a cable onto the butterfly(you will have to ad a return spring). These things don't blow up like 4 strokes if you rev them too high.
the flange for carb is the same as other tecumsehs. Im running an adjustable carb off an old 5hp 4 stroke on mine
blackthunder
Here is the pic with the shrowd off, the vain is connected to the butterfly...
sexyvicta
and? remove the vane + linkage and throw in the bin.
attach throttle cable.
profit
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
You simply need a linkage which pulls one spring that is not quite as tense as the governor spring. That way, you putting pressure on the gas pedal will not overcome the governor tension. It's really not that complicated behind it. look up fixed to variable throttle conversion.
Iron John
NA
Personally, for a 4 year old I would probably keep the governor. Once the kart is built and dialed in, and your child gets some stick time, you can always remove it later.
The governor will make operation a lot smoother, for example going up hill, as a beginner driver will not be as smooth in modulating the throttle. The same is true to help prevent a downhill runaway.
Brandon1023
needs an oil change
FWIW, two strokes last at maximum RPM's as long as it's rich enough to keep the bearings lubed.
true. you can rev it faster than 12k rpm, but thats under lean conditions, and that doesnt provide adequete lubrication. the compromise is richening up the condition which results in decreased rpm output, however it keeps the engine lubricated.
sexyvicta
but you may be able to rev past what ever that max rpm should be. ie max piston speed/acceleration determined by ring flutter con rod strength etc, yadda yadda.
im reving mine out to about 5-6k ish and its fine. doesn't seem to want to go higher than that on stock porting
