google sketchup
fowler
Bullsbrook West Aus
iv finally got sketchup and done all the basic tutoirals
but what i want to know is how do i rotat somthing about its axis
for example to make a sphere u would make a semi circle and rotate it around the centre axis
i may have the totally wrong idea im not sure
i use to use prodesktop but it ran out and it is hugely expensive
Bluethunder3320
autodesk here is like $6000 for the starter.
to rotate it, im not sure, but i think you need a center point that is the axis you rotate on, then use the rotate tool.
KieranM
Doin It!!
Kilkenny, Ireland
I got a student version of solid works, I prefer it over Sketchup, got it for free, there is an addition costs 300euro and runs out in 150 days, but there are ways around everything ;)...not to say that I broke the law or anything...
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
+1 Kieran, I get free student versions of autodesk because I took a class that used it. I love inventor
CriticalMass
East Bay CA
I never got as far as rounding the edges for tires. I got my size the way I wanted. But couldn't get all 4 tires on the same plane and lined up so I said f it.
I am bad at drawing period. Computer or not
Bluethunder3320
i was going to get autocad free for 4 years from school but it turns out its only windows compatible.
r97
Measure twice cut once
Massachusetts, USA
devino :roflol:
i use the extrude tool a ton, once you learn how to make it you can make all kinds of stuff, made a tc driver in a few minutes, i also use it to make mini bike frames, good for headers too. it basically allows you to pull any 2d figure along any guide line.
1. draw guide circle.
2. draw semi circle to be made into sphere.
3. click extrude tool onto one face of the semicircle, and begin to drag cursor around edge of guide circle.
4. continue to drag all the way around circle, then put the cursor on the edge indicated by the big red arrow.
5. ta-da!
EDIT: wait, you learned how to do that!!!!!! :mad2:, to remove edges, go to view, click edge style, click edges.
i bet there is a yt vid for this........
