Going to mount a tank
Bbqjoe
Banned
Location, Location
[/IMG]
I'm going to be mounting this to the Baja after a bit. I'm going to take my time with the paint job, and maybe give it a week between coats.
I'm counting on this tractor paint to be pretty tough stuff.
Anyway, you can see the tabs on how this gets mounted.
I'm definitely not going to weld. I could drill and bolt it, but I'm a little leary of more holes in the frame.
Do they make some sort of big hairy hose clamp for this application, or do most folks drill and bolt?
:serioussmiley:
Thats a nice deal for that price... Man I wish I could find a deal like that here......Even in US$...
Ive seen a few ideas out there...
Here's an idea...
This uses a welded tab for the pipe clamp to slide underneath, kinda how a typical exhaust pipe heat shield works... If its new just like this, then mounting a tab wont be hard at all.....
There is a few others on this site for there mounting points, these are for motorized bicycles.
http://custommotoredbicycles.com/pa...lters/motorized_bicycle_gas_tanks_moped_tanks
Bbqjoe
Banned
Location, Location
I got the first round of sanding started using 150 grit, and did the coating on the inside of the tank.
I also made up a bracket and installed a series of petcocks.
This thing just fits. I'm going to lose a few degrees of turning radius, but I think I can live with it.
