go kart gear system
chachaman811
i have a small street gokart, its 3 hp and its has a nice frame, i got it for 100$ im upgradeing my engine to a 5-7 hp, right now i have a cintrifugal clutch, and i want to buy/make a manual clutch useing a bike brake cable, i want to rig a gear system {2 speed} maby out of a old bike cable, i dont know, any ideas, i dont have much money to spend,
Bluethunder3320
i think the best way to make a manual drivetrain, cheapest, is a belt tensioner.
however for the 2 speed part, that will be much more complicated. search the forums for a member named "wim" he made a 2 speed gearbox and showed how to.
one idea is to make a belt tensioner up to this home made gearbox, then a chain from that to the rear sprocket.
^^^ it might be too complex and hard to make that you might just end up sayin screw that and either get a simple centrifugal clutch or a one speed belt tensioner.... im not sure of the resources you have acess to, but you really need a welder, grinder, those tools. if you have machining tools that would make it alot easier.
welcome to the forums!
chachaman811
yeea i have a cintrifugal clutch right now, but my engine is only 3 hp. i modded it and it probably runs 3.5 or 4 but yea i have friends with tools, but thanks for the advice. and im not that into pullys {i would have to remound my engine,} but im gonna sell it anyway so ill look into that
chachaman811
thanx, but i dont have the money or time to do that, im thinking a manual clutch and just a bicycle shamo {high prefourmance} bike shifter, the main thing i need is a manual clutch, i found the clutch online, but i wouldnt know how took hook it upp. and i have some old moterbike handle clutchs with the cables but i dont know how to install a mannual clutch, idk how the hook upp. is there like a leaver or something?
r_chez_08
Should be in the shop...
Cornwall, UK
Bike gears are not up to it.
I would reccomend you sell your 3hp and clutch and try to find a bike engine if you really want gears.
Krustalien
Battlebot builder!
South of Spain.
They're pricey but torque converters are like having an automatic. Just a thought. I believe somewhere in the order of a Comet 20 or maybe 30 would be what you need for the size engine you're looking at.
chachaman811
im looking at a 6.5 hp honda clone... im getting it soon, i took off my 3hp and im cleaning it upp , i might sell it on ebay for around 60-100 but i really want a manny clutch, with or without gears, i looked at some gokart mannual clutches and i dont know how they would set upp, i want a cable opperated one {to a clutch handle off a motter bike} but does anybody know how to set one upp??
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Belt tensioner is the only price-effective method.
Wim
Jazz Maverick
Oz
+1 Belt tensioner is the cheap and easy way.
Or get a small dirtbike engine with clutch.
r97
Measure twice cut once
Massachusetts, USA
don't forget the option of a 2 or more speed belt tensioner!!!!! use several belts, each with a different ratio, and engage one a ta a time, similar to a manual engine. search the forum for "two speed belt tensioner" or a similar search, a few people have made, or started to make them (devino).
devino246
Lynchburg, VA
Ill get it done one of these days:D
2 Speed Belt Tensioner Build
Ya know what sucks? Ive got a 3 speed trans sitting around that had some parts borrowed from it. Too bad parts for it are near impossible to find. Although 1st gear isnt synchronized so that would be a pain.
