wait what?
an off road kart with 280 lbs incl driver?
sounds like very lightweight...
that'S LESS than the Honda NSR125R weighs dry (300lbs no fuel, no driver)
are you sure about that?
Anyways, if your kart is really that light,
I see no problem in using such engine, BUT since I don't know WHAT engine you have I cannot give any advice about the gear ratio.
Differnt models come with different set ups
So we need to know (or YOU need to know)
let's just assume it has a 3.25:1 primary reduction
followed by a six speed gearbox.
with the following ratios:
3.09 :1
2.00 :1
1.47 :1
1.21 :1
1.04 :1
0.92 :1
So what you wanna do is take the second to last gear ratio (1.04 :1) and multiply that by the primary reduction (3.25 :1)
Then take the result (3.38 :1)
as your top speed base.
the last or overdrive gear might not provide enough torque,
so just expect that to be some sort of high MPG cruising gear;
if you end up with a little more top speed in the end, it won't harm I guess
Now let's assume you have like 30HP @11000 rpm
to get to 50mph on 18" wheels @11k rpm you need an overall ratio of 12:1
now all you need to do is divide that target ratio by the engines internal ratio (3.38:1)
and you end up with 3.55:1 for your final ratio
since the engine sprocket is most likely in the 14T range.. you'd need a
49 or 50T axle sprocket.
But to get it right you need to know the engines (or transmission) details.
PS the numbers I took are for a NSR125R engine yours will be different, but alike.
