ojait
Hi I'm Tony from Ventura, CA. I just recently started fabricating a go-cart. This is my first 4 wheeler. I've previously built a couple of electric trikes and installed a kit motor on a beach cruiser. I got the frame of the cart pretty much finished with the front spindles attached. I have a couple of photo's to post. What's new to me and a little confusing is the rim/hub nomenclature. ,....But that's for another thread! That's why I joined your site. Forum dialogue seems helpful and knowledgeable. I hope you all won't mind me asking to many wheel and hub questions. Thanks in advance. ***here are some photos of my kart project. The center support and front and rear cross pieces are 1 1/2 inch rigid conduit. The rest of the braces and struts, depending on placement, are 1", 3/4" or 1/2" electrical conduit (EMT). I welded the larger pieces with a arc welder than went to a MiG with the smaller members. My MiG went south so I'm back to stick welding until parts arrive. I'm putting it together when I can afford too. I have the tires (slicks) and only the rear rims. I have the engine. I'm planning on using the B+S from a scraped generator. I believe it's a 18 hp and has electric starting. Should be a quick little ride!
to the forum, and ask away!!!!
Could this be a new record ? Did you run him off in only 3 post ? You guys are getting better at this.
