gearing
Oxymoron
Newbesque builder.
Maryland
Replacing worn parts is going to be cheaper than buying a new engine. As long as he block is OK, you could just build the engine again
^This.
As long as the piston and bore are okay, the engine is okay. Everything else is replaceable.
Start with the carb ;)
If I'm correct that should be a GY6 engine just like this one (ebay #310703597764)
right now there are 7,392 results for gy6 at ebay, so I'm pretty sure you'll find all the replacement parts you need to fix that engine.
z34dohc@hotmail.com
yes it is a gy6 motor, i have to get the vin and see if i can match up with one from ebay, i also talked to the person who tore it apart and he said the cylinder was scored? oh ok. which would mean the piston must have gone resulting in the loss of power.
Oxymoron
Newbesque builder.
Maryland
Oh. You could get a bigger piston and bore the cylinder... but you're probably on the right path just getting a new one.
