Gearing Question
Jcotz
...wasn't there
NY
Okay, right now my kart has a 12 tooth clutch and a 60 tooth sprocket. It also has 11 inch tires, do you guys think that a 6.5 hp engine would be enough to get it up to 30 mph and still have some torque?...Or what gearing/hp would you recomend?
Jcotz
...wasn't there
NY
What would you recommend to get it up to that speed? Also... I was looking at the speed calculator, and how does it figure in weight?
Jcotz
...wasn't there
NY
Removal of governor would do it. Weight is normally not a factor when figuring out potential MPH.
Lighter is better of coarse.
I was just saying that because my kart is light and I am light, so it may make a difference. Also...I might not want to remove the governor due to lack of experience and not wanting to have to buy a new engine. Also, I know hp≠speed, but how much power would it take to attain my goals, with the gearing I have?
Russ2251
AZUSA:Powered by LAWN-BOY
To attain the higher speed you require (30 mph) requires higher rpm with your current set-up. Hence, the removal of governor.
Otherwise, to reach 30mph means going to a smaller axle sprocket, meaning that mph would come up, but torque would be sacrificed.
r_chez_08
Should be in the shop...
Cornwall, UK
You would need to change the axle sprocket for around 45t, however, I would suggest removing the governor if you plan to hit 30. You can currently hit approx 25mph with your current setup.
See here
Affordablegokarts.com
There is an easy to follow governor removal guide. You would need 4600rpm to increase your speed to 30.
Another way to boost your speed a little is to back of the throttle screw on the lever. This can get you a few 100 rpm.
