Gear reduction removal
billdan
I have a Honda GX340 horizontal shaft motor off of a pressure washer. It has a gear reduction box built on the side from the factory. I believe it is 2:1. Can I remove this box and get rid of the gear reduction??
hello and wellcome
Lets see some pic of this motor and how it is setup...
Some Redux are a bolt on.. others are part of the engine, and need new crank, sideplate and potentially other things.
anickode
S.E. Michigan
And some of the bolt-on ones mate to an engine with a stub shaft, which is nearly useless for a kart, so again, new crankshaft.
Jhoppe
Indiana (IN)
Correct me if I am wrong, which is entirely possible, could you not use a jackshaft to undo the reduction? If he can't get the reduction box of easily? Or even use a smaller rear sprocket to compensate?
Depends on the redux...
If is a wet clutch it can be compensated for in the gearing... if it is geared.... then no... as there isnt a clutch able to mount due to low rpm's...
anickode
S.E. Michigan
If it's geared, you *could* use a jackshaft with fixed sprockets to double the speed, then run the clutch of your choice off that, but it would make things more complicated, bulky, and expensive.
Is your GX340 a true 340 (337 cc) or is it a detuned 390? (That's what the newer ones are) You'll need to know in the event you have to buy a crankshaft. It'll be cast into the block on the side.
65ShelbyClone
SoCal
The crank is most likely short and splined if the reduction box has no clutch.
If the spline is by some chance 25mm x 13, then a wide range of motorcycle sprockets would slip onto it.
