I'm currently in the process of building a drift trike (in the UK), mostly as a stepping stone to larger projects such as a go kart/buggy and have a few questions regarding gear ratios.
I've got a Lifan 125cc engine with a manual gearbox, and am trying to get my head around the correct gear ratios.
From what I've read countless times you need a gear ratio of about 5-6:1 in order not to destroy the clutch. With my current setup I'm managing a ratio of around 4.1 (13t front 54t back) with 11 inch wheels.
In my understanding, with a gear ratio of around 2:1 from the clutch to the front sprocket through the gearbox and in first gear, the total ratio is 2:1 x 4:1 = 8:1. By forth gear the ratio is reduces 0.96:1 x 4:1 = 3.8:1.
If my reasoning so far correct then I'm not in danger of burning up the clutch until I reach 4th gear - which is something I'm willing to live with (if anyone has a different opinion please say!).
The obvious resolution to all of this is to increase rear sprocket size or decrease front sprocket size, but due to the limitations of my setup this is not possible. I can find a minimum of 12t (428) sprockets for front and on the rear my 54t is already way too close to the ground (~8.5" sprocket on 11" wheels).
This leads me on to my next question of ground clearance of rear sprocket. My options here are to use a smaller sprocket or using a jackshaft which I'm trying to avoid for this project. Using a smaller rear sprocket will reduce my gear ratio but if I'm correct this wont cause any issues until I reach 4th gear.
How did Colin Furze get away with using two front sprockets? Just taking the hit on burning up his clutch regularly?
I hope you can help me with my many questions!
Many thanks in advance.
