gear ratio for a 12.5 hp engine?
harry
hi I have a 12.5 hp briggs and Stratton engine and I was wondering what the lowest gear ratio would be for good acceleration but mainly top speed above 30 mph. the go kart has 18 inch wheels and me and it put together are about 130 kg.
KartFab
Dallas, TX
40 series torque converter, 6:1 ratio. 33 mph top speed. You can also get away with a different ratio with a target of 39-40 mph and do fine since the engine is so big.
If you go for a centrifugal clutch, the most speed you should look for is 22-24 mph and you will wear out the clutch if you go any faster, or try to climb any sort of hill (I believe).
:iagree:
fully, totally AND completely :lolgoku:
you can gear as low as 5.1:1 with a clutch and even 4.8:1 with a torque converter since your engine still provides enough torque to get you moving,
but if you really want the most fun you always want the best acceleration (reads torque) possible.
And you're going to miss the torque on the very next hill.
So 6:1 and take it for a ride, if you're not satisfied you can still change the sprocket.. costs maybe 12 bucks and 12 minutes :D
harry
Ok great thanks guys! Where I live in England there are no hills whatsoever near me so they won't be a problem! I have a centrifugal clutch already so I'll go for a gear ratio of 5:1 since I have found one for £10 but I can't find any with 60 teeth below £30...
5:1 is a bit of a stretch.. I don't think it'll work very well.
I wasn't talking about climbing the Alps,
I was talking about any ever so tiny road inclination.
I bet with a 5:1 ratio I can make you burn your clutch within 5 mins...
just find a curb that's about 10cm (4") and roll your kart against it...
now start it up and try to climb that curb...
you'll fry the clutch.
we had that exact same scenario just a couple of days ago here on the forum.
I don't need to tell you that the clutch is more expensive than £20 ;)
harry
Oh ok not even 12 hp engines?! And also can I put one of those racing air filters on and does the petrol tank have to be above the engine?
oh sorry.. uhm just a filter.. could work, but it's rather pointless;
since it's less restrictive (more air) you'll need more fuel (means rejetting the carb)
and since you then have a higher intake you need to get a freeflowing exhaust as well.
the fuel tank must be above the carb as long as you don't have a fuel pump installed
the carb is gravity fed ATM.
But it doesn't need to be where it is right now.. you can mount it anywhere you want as long as it sits higher than the engine.
Or you need to get a fuel pump (pulse powered)
then you can mount the tank to the floor if you wish ;)
