gc160 exhaust
Jackrod4392
:welcome2: Im building a go kart with a Honda gc160 pressure washer engines, but the exhaust is gonna blow on me, how could I fix that or make a new header
thanks for answers
carter
You could cut the flange off of the old exhaust and use that to make a new one.
cheap_thrills
SE Indiana
I actually just finished making an exhaust for my GX160, only cost me 4.99 for the screw on muffler tip, and a scrap piece of 1" tubing. I will try and upload a pic or 2 here shortly
firemanjim
Just kartin' around....
Houston Texas
:welcome2:
There are several threads on building exhausts and mufflers in our forum. If you try (hint hint) the search feature, it will find all the posts for you. It only takes a couple minutes. You should try it...... :wai:
Also, it may not seem like it, but filling out your location can actually help with receiving help. Look at it like this.... If you ask, where is a good place to order parts? I wouldn't respond to that...... BUT if your location was filled in, and I knew you lived close, I could tell you, hey just go over here to such and such. They got the same tire same price no waiting for mail......
See how helpful that WOULD /COULD have been?:thumbsup:
cheap_thrills
SE Indiana
Understood, I was just simply implying the approach I took. He could cut the old muffler off at the flange, and with a properly bent piece of tubing he could just route it around and out the side. Then top it off with a $5 tip.
cheap_thrills
SE Indiana
GX160 exhaust
Here is something like what I did. I even went a step further and port matched the flange. I'll post a pic of that here soon. But if he got say a a candy cane shaped pipe and welded it to his original flange, he could route it around the side. Just my thoughts...
cheap_thrills
SE Indiana
Port matching exhaust flange (GX160)
I cut the original muffler from the flange which had just a circle shaped exhaust port and used a carbide and die grinder to port match it to the "D" shaped port on the engine itself. The tubing didn't cost me a thing, so all I had in it was the tip for $5. Cheap thrills at its finest ;-)
qtband
St. Louis, MO
The exhaust port is not the same on a GC160, so this doesn't help the OP.
A 3/4" street 90 with the threads ground down will fit into the exhaust port of the 160. Then take a 1" washer and drill 2 holes in it to match the bolts on the exhaust port. Weld the 90 to the washer. You now have a 3/4" threaded female end and you can route the exhaust any way you want with additional 45's, 90's, or whatever.
See pics below...
This seems as good a place as any...
Some time ago, I learned a little trick; if you hold down your "Alt" key then press 248 on the numbers pad, you get ° :D
