Found an 8hp Briggs Flattie
Kentucky Boy
Bowling Green, KY
I found this 8hp Briggs Flattie for sale for $50. It appears to have a tapered crank shaft. Are there any torque converters made to fit a tapered shaft or is this motor not good for use with a torque converter? It's only $50 so I'm interested in buying it for future use. Thanks.
One pic of the front tins.
Kentucky Boy
Bowling Green, KY
Yeh I've been researching and I think I could get a different crankshaft. Sure I could get a predator but I already have a built one. The Briggs are just way cooler and are made in USA.
gman3850
gilbert az
I've got an entire motor that is sitting in the parts bin of your lock-in for some parts for the 8hp flattie. It has a straight crank
Staff Murderator
...Kind of hard to justify, when you can you can go with a brand new Predator for under a hundred bucks...
Aha, another Chinese engine cultist aye? Send in the torches and pitchforks!
KB couldn't have said it better. Briggs are just cool and anything is easy to justify...when you like it.
Randy H
Not a cultist at all. I have a kart with a Briggs 5 horse, one with a Tecumseh 5 hp. A couple with predators, big block and the awesome 212.
If money is a concern, and it is for alot of guys. It's hard to beat the bang for the buck a Predator offers. Especially considering the upgrade possibilities. Sure there are things (even free) you can do with an 8hp Briggs to increase performance. A billet connecting rod?
If planning on keeping the engine stock and the price is right, go for it.
But a engine that starts at $50, needs a new crankshaft. Quite possibly gaskets, seals, bearings, rings, valve job. An engine that a Predator will run circles around, That's hard to justify.
pRoFiT
Can't buy it?, build it!
California
Yup, that sounds like you want to join the China Cult for sure.
Don't worry i work for a company that sends all their manufacturing to China too. They have cheap labor. Quality is what we make them do. Put in a good process and everything is fine. :thumbsup:
Welcome to the cult.
謝謝
Xièxiè
Predator FTW!
Kentucky Boy
Bowling Green, KY
So I went and bought the 8hp. It looks good. Nothing is broken and it will run. I will be needing a straight shaft crankshaft for it. Gonna plan on making a new custom intake and putting on a Mikuni. Needs an exhaust header also.
Gonna check on a billet rod and remove the governor. Here is a pick of the tapered crankshaft that is used in generator applications.
Hey Gman. How much do you want for that crankshaft?
So I checked out this motor today. Turns over great. Good spark, good compression. Took the head off to check out the cylinder and valves. Found some carbon build up.
But it was very soft and easy to clean up with a dreamel.
And the cylinder looks perfect. No scratches at all.
karl
North east Ohio
I wondered how many rpms and power the 8hps can handle. Plz find out! Many 5hp performance tips can apply to this motor.
Kansaskart
As a kid the 8hp briggs with no gov were my favorite. While I mostly use predators today, I wouldn't hesitate to use a 8hp briggs old school. Its been a long time but it seems the briggs had a little more oomph under its belt, esp low end, than my 212s. But my memory sucks too. I liked the briggs better than my macs because it was much more reliable and less work it seems. What the ****, buy it in try it out. I have an old mower with a briggs cast iron horizontal 12hp its a beast.
Kentucky Boy
Bowling Green, KY
I plan on replacing the rod and removing the governor so might as well replace the crank while I'm at it.
So my model number is 194412. Would a straight shaft crank from another 8hp motor fit or are there certain model number cranks I should look for?
Staff Murderator
KB: What's the entire model number, engine type number and code?
Fine work on the 'de-carbonization'. Most mild mannered men of this here 21st century might be appalled that carbon removal is part of regular maintenance, every 100-300 hours or so, per the manual. I think opening the engine up in the manner prescribed might frighten them off.
..of course these are the men with manicured nails and an inherent inability to swing a hammer. :rolleyes:
Kentucky Boy
Bowling Green, KY
Definitely should take the head off and remove the build up often. Even on a new Predator it builds up fast and will score the cylinder when it breaks loose. My number is 194412 1126 01 93021130.
zeuspwner
Katy, Texas
Looks like we picked up the same engine about the same time. Only difference is some parts were missing (ie: everything prior to carb). were you able to find the crankshaft?
anickode
S.E. Michigan
The other thing to look out for with generator engines is the complete absence of an idle jet in the carburetor.
bigrigbri
Derbyshire UK
If you are stripping the engine why not let a decent welding shop build up the end sort of parallel and machine it back to your required size.
A good welder shouldn't put too much heat in the shaft to distort it. Cheap as ****.
anickode
S.E. Michigan
A good welder who can build up pultiple passes on a heat treated part without damaging it, won't be cheap. I can tell you that welding that out with TIG would be a multiple hour process on a positioner, monitoring interpass temps... It would not be cheap as ****.
A machine shop that has a mig welder laying in the corner and can booger the shaft till it's nice and fat because it's just getting turned down anyway will be cheap, but wrong. Will it be an issue long term? Maybe, maybe not.
Kentucky Boy
Bowling Green, KY
Probably cheaper to just buy a used crank. I just need to know what to look for. What 8hp motor crank will work? I'm not familiar with parts interchange on this motor.
