bucky242
the floor board on my go kart shakes when I drive it and when I step on it, it shifts down. Other than welding a piece on it to strengthen it what could I do?
you could put in a support bar as previously mentioned, and since welding isnt an option, drill holes in the floorboard and use u-bolts or something to hold the bar in place.
just use a thicker support bar if you they are too long, or after you install the u-bolts (i would put the nuts on the underside of the floorboard) you could cut the extra length of bolt off with a hacksaw so they dont catch uneven ground or anything. just make sure you use a good thread locker or self locking nylon nuts.
