Finding Fabrication Materials
SpiderSpartan
Cincinnati, Ohio
As the weather starts to warm I'm thinking about getting back out in the garage. I've got a few projects in mind. Only problem, same thing I always run into, where to get fabrication materials? I'm talking steel plates and sturdy, weldable steel tubing. Local big box stores have thin plates (sheets really) and short tubing.
So how about it, where do you get your fabrication materials? I'm in southwest Ohio, between Cincinnati and Dayton. If anyone knows somewhere in my area I'd be especially grateful.
MadManAndrew
Fun-Club Chairman
Dallas, TX
I get mine from fence supply stores. Or just google "metal Cincinnati". They all carry a ton of different types, sizes, gauges of metal. And to top it off it's about 1/8 of the price of the same material at Home Depot. The box stores gouge you on stuff like that.
You can also order it only from places like metalsDepot.com but similar to Home Depot these places charge a premium for the convenience, 2 to 10x as much as you would pay at a local fence or metal supplier.
SpiderSpartan
Cincinnati, Ohio
Thanks! I googled metal cincinnati and the first listing that came up, https://www.metalsupermarkets.com/cincinnati/, looks promising. I had tried googling some stuff before and all the results I was finding looked like places to buy in bulk. If this place doesn't pan out I'll check out the local fencing suppliers to.
MadManAndrew
Fun-Club Chairman
Dallas, TX
Unless they specifically say wholesale they won't require you to buy more than a stick which is between 20 and 24 feet, and I haven't found a place yet that wouldn't cut a stick down to pieces that would fit in my truck.
Ebrownie
Western Montana
NEVER buy from Home Depot or a similar store. They charge way more than a metal supplier. And I agree with Andrew, most suppliers will happily cut the pieces down to whatever size you want.
SpiderSpartan
Cincinnati, Ohio
I stopped in my local metal supermarkets location and looked at some stuff. Right now I've been thinking about trying to make a strut tower brace for my car. Figured it would be pretty cheap, so if it didn't turn out or broke, no big deal. I was surprised when they told me 6' of steel tube and a 6"x12"x1/8" steel plate would run me over $100. for that much I'll cough up the extra $100 for the professionally made piece.
Maybe I asked for the wrong stuff, 304 Stainless Steel. What types of metal would you guys use to build kart frames?
Stainless is no harder to weld than mild steel and can be welded with standard mild steel wire and C25 gas. Won't be the best in the world but totally doable.
308 stainless if I recall is more of the popular alloys used, been a while since I did stainless welding in college, but that's what we used. If you want to weld stainless to mild steel, you would want to use 309 wire with straight Argon gas, however it's not 100% needed. It's just the welds will be susceptible to corrosion using mild steel wire, rather than 309 wire. But it's a cheaper route. 14 gauge and thinner stainless are susceptible to warping, so keep that in mind.
SpiderSpartan
Cincinnati, Ohio
Ok, thanks guys. I called and asked for a price in mild steel. Comes out to just over $45 with tax. That's for a 6' long 1" OD ~1/8" thick tube and a 1/8" thick plate 12"x6". At that price I think I'll give this a go.
Texan
Senor Member
Deep In The Heart of Texas
Just ask if that is for Hot Rolled or Cold Rolled, hot rolled is almost always cheaper.
SpiderSpartan
Cincinnati, Ohio
Thanks for all the advice. I just got 6' of cold rolled 1.125"OD x 0.065" and a hot rolled 11ga. 6"x12" plate for just under $40. The guy at metal supermarkets was helpful and patient with me not knowing what I really wanted or what I was talking about.
I have found they typically will let you look at what they have, if not escorted around to the racks....
For the most part they cater to the average people getting a chunk of something and also businesses that run a production.....
SpiderSpartan
Cincinnati, Ohio
Not exactly a go kart this time, but I was able to fab up a strut tower brace for my car. I installed it to make sure it worked ok before I go back to paint it. Saved me over $150 making it myself with maybe 5-6 hours of work including design.:wai: Thanks again for the tips.
