Engines; what is best?
Jcotz
...wasn't there
NY
With a guide that has pictures, common sense, and basic tools, you should be able to remove it fairly easily.
r_chez_08
Should be in the shop...
Cornwall, UK
You want to watch it. Might be worth buying a cheap tach from eBay. I would not take an old Briggs you do not know the history of much over 4500rpm with stock flywheel and rod. It also obviously reduces the life of the engine a little.
Jcotz
...wasn't there
NY
The thing is, you must know the risks. There is a chance that it could lead to catastrophic engine failure an possible injury, and there is a chance it could lead to a lot of fun :thumbsup:. If you want to be safe, then upgrade your flywheel and rod. The most danger of removing the flywheel is on clones. Also, if you do, just exercise common sense. Don't over rev for long periods of time with no load, etc.
r_chez_08
Cornwall, UK
I would say clones are no worse than many, especially an engine you don't know the history of. I have heard of rods going on techumsehs and briggs engines at around 5k
The clones have got bad reputation because of box stock racing at 5800 with stock wheel
Jcotz
...wasn't there
NY
That's true, I just try and be wary about the possible errors in quality control.
falcon1
I'll keep this to myself...
Do all engines have a governer? My parents don't want me starting with a go kart as I have never really done anything like it before. Luckily, I have a racing pocketbike that I won at the PNE. It is fairly fast; top speed is 28 mph. Problem is, the heavier the weight, the longer it takes untill the acc really kicks in. On our road, that means only a short distance of going fast at all. Since the turning circle is so large that you have to slow to an almost complete stop, I can't even do laps ever increasing in speed. It also has problems starting, maybe because of old gas, but I think the spark plug is cloged. It had that problem before and my dad fixed it, but as said before, I need to do it if I want a chance at a go kart. Since there isn't really enough space to go fast as the bike is, I would like to remove the governer to hopefully give it a bit more kick off the line.
