engine ?
pinehillian
south somewhere us
hey all pine here, I just got a kart, couple things say klipperkart. I need to replace motor but not sure what to get. will be used by adults and child. from what I read it has tc rather than clutch, everything seems to be there except belt. anthing to check tc out and motor is briggs with no cover so don't no size of it , hp etc. (motor no good) looks maybe 5-6 hp. real big rear tires on it,thanx in advance pine.
KartFab
Dallas, TX
piactures would help, but just for you to investigate, the predator 212cc engine you can get at harbor freight for $100 is what most people put on go karts as a replacement engine. It replaces most 4-7 hp engines with a 3/4" horizontal shaft. Mounting pattern is the same, shaft is a little shorter, but still works most of the time.
Poboy kartman
Senior Moments Member
White Settlement Texas
Welcome to the forum and thanks for filling out a profile location.
Now.....ummmm...."pics would help ".....errrr.....no....:useless: (I can't tell whether you have a TC or want one....
Also, one thread is sufficient for each question....no need to start multiple ones.
Finally, we need to know how "big" exactly those rear tires are and sprocket counts for either JS or CC and axle sprocket.....approximate weight of kart and driver....before we can advise on engine size....
