Engine won't stay running
gallagher19
Fonthill, Ontario, Canada
I purchased this engine which is a Honda 5.5hp racing engine from a guy last year. I finally need to use it. Was told it runs great, yet I never heard it running. Dumb me!! It starts up no problem, has a ton of compression, yet I need to run it with the choke on at idle. I can rev it up a couple of times than it dies. It will not run at all without choke. I have cleaned the carb up really good (so I think). I took the recoil cover off and found the flywheel was very rusty. Took off the coil and it was clean. Sanded off the rust from the flywheel and replaced the coil. Still does the same thing when I rev it up. Totally quits. What the heck could this be??:furious2:
Poboy kartman
Senior Moments Member
White Settlement Texas
Definitely carb.....it's most likely still dirty although it may be jetted too small....
I would say clean it again...(boil in lemon juice) ....and check/clean all small passages with a small wire....
thisismyusername
Donut Eater
Yea i would definitely say it's the carb. When you clean it again make sure you stick a little wire or some thing down the jets and get any gunk out of them. Try to clean every little crevis of the carb like poboy said. Let us know if it works!
Pay attention to the plug below the black idle screw; the passage below it forms part of the idle circuit...
Also check that the fuel tap is allowing enough fuel through & that the float & needle are set & working correctly; your problem could simply be a sticky needle...
gallagher19
Ok, soooooooo I had the carb cleaned thoroughly once again. Did find some more crap in it. Totally cleaned out, yet I still have to run it on 3/4 choke. Once I take the choke off it will not stay running and it will not give me max power. This is REALLY starting to piss me off!!. Now Fabroman you say to pay attention to the plug below the black idle screw. What exactly do I check on that part?
Half-breeder
"Edit" button removed
#27 is what we are focusing on... the #1 is a rubber ring gasket/seal.
You remove the big black plastic set screw(#11) completely... pry up on the black plastic tab youll see under the screw you just removed... #27. Check the rubber ring and see if cracked or worn looking(recommended to replace anyways). Carb clean the passages inside the hole, where you took #27 out of. Blow dry/inspect and reassemble.
If you have a GX model engine the carb should have an actual fuel/air mixture screw (normally broken off due to the design of the screw)... #5. If yours is broken off you may wanna replace 'that' aswell, not because its broken off... but because you cant clean out the passage thoroughly w/out removing it, and reinstalling it is even harder when the head is broken off. But some have a cap that is put on it to prevent it from unscrewing itself out which would make the engine run leaner and leaner till it just wont run/start... w/out the choke on.
Another thing to look/see is the fuel level. The stock tanks outlet's design has a small flaw... at 'low' levels at times, the inlet will suck air instead of fuel... which is equivalent to running the engine lean, meaning the choke would need to be on inorder to provide the proper mixture of fuel and air to continue the internal combustion process... the screen in the outlet may be clogged too... somethings to check.
gallagher19
Is it an adjustable carb? If so might be running too lean, maybe drain gas and put in fresh gas?
It is an adjustable carb. I did drain the methanol (not gas) and put in fresh methanol. I am going to replace the plastic piece which is between the carb and intake. Another poster on here found that was his problem.
gallagher19
Mine is a GX therefore #5 pertains to me. I did take that out and clean it thoroughly and the screw is fine. Fuel level could be a problem (will fill to the top) or maybe the screen in the outlet. I will check that also. Thanks. I am going to replace the plastic piece which is between the carb and intake also. I have all new gaskets, but the plastic piece was the problem for someone else with a clone engine. Who knows it is worth a try. Thanks guys for the ideas. I know we will get it sooner or later. Hopefully within a couple of weeks. My big race is the end of July!!!!
gallagher19
okay here goes again. I checked all of the above. LOL Not sure what was the real cause, but I cleaned the carb AGAIN, checked the tank, the screen in the outlet and changed the plug. Still didn't work right. I finally decided to put all new gaskets in it and a new plastic plate in it. Now I am seeing progress. Now I have to figure out how to set the carb right for idling and running. It will start and run without the choke on. But, it won't idle worth crap and the engine flutters and wants to stahl when it warms up. I took it out for a few laps and it still isn't right. Still have some work to do I guess. Any more ideas would be GREAT. At least I am heading in the right direction.
Half-breeder
There are soooo many variables that 'can' prevent a stock engine from running properly (carb being the norm, seeing as that it feeds the engine)... and troubleshooting an 'altered' engine, is even harder. When I read 'racing' I wasnt aware of the methanol used for fuel (must have a turd load of compression)... but glad things worked out for the better.
Tuning a carb for an engine isnt all that 'hard'... just gotta find the 'ideal' fuel/air ratio (#5 & #12). Turning #5 Clockwise richens the mixture while counter-clock wise leans it out. Turn it slowly and give each turn a second or two, for the engine to catchup w/ the new setting. If you didnt know, running an engine alil rich is better than alil lean (especially using Methanol). So ideally you'd find the halfway point, between the 2, and go slightly more clockwise/richer. "If" your running a mid/high cam things can be alil bit harder to fine tune... but w/in time/trial/error, youll find the ideal setting. Keep watch of the spark plug... it alone will tell alot, by its appearance (after usage) how/what the engines performance is. RPM's can be dropped lower on a richer running engine... but dont drop em too far low, for a # of not good reasons. My way of setting RPMs is finding the LOWEST and what 'I' consider too high... and go somewhere in the mid/high range.
