Engine, Tourqe Converter, Sprocket
karlskartisthebest
Hello!
I am new here and plan to stick around for a while. I am about to build my first go kart using the plans from Kart Fab. I just had some questions about finding the correct sprocket and Tourqe Converter for this engine. http://www.ebay.com/itm/282062439456
Are there any tips that you have for me? I have read the smaller the sprocket the quicker acceleration but slower in the long run. And the opposite for the other way.
This is the converter I was thinking about buying. http://www.ebay.com/itm/262204798399
I'm just lost on sprockets at the axle.
Any help will be greatly appreciated.
Atlanta, GA
That engine is not compatible with that TC, too much power. You will need a 40 series TC, which doesn't have a back plate, which means you will need to build/install a jackshaft on your kart to support the driven pulley of the TC. Your target should be between a 5:1 and 6:1 ratio at the axle.
