Engine spins backwards what can i do
munsonater
My 420 cc predator spinds backwards how do I reverse the way the shaft spins is there a torque convertor I can buy
I really doubt it spins backwards. It would require a camshaft specifically ground to run in reverse for it do so. If you are looking at power output shaft from the side it should be turning counter clock wise. You can always flip the engine around 180 degrees on the mount and the rotation will now be in the other direction. Might have to change location of sprocket.
