Engine oils
r_chez_08
Should be in the shop...
Cornwall, UK
Hi,
I have been using 15w40 oil in my kart since i bought it.
Firstly is this ok?
Secondly what do the numbers mean? Eg the difference between 10w40 and 15w40, or 15w30 and 15w40?
Thanks
Rob
r_chez_08
Cornwall, UK
aww man! do you know what the difference between 10w30 and 15w40? just we have about 50L of 15w40 for tractor oil, and thats what i have used, cos its free for me!
Rob
DCProductions
Cockney Ragamuffin
Louisiana, USA
If I'm not mistaken the first number is the "weight" of the oil (viscosity) hence the "w" behind it. The larger the first number the heavier the oil. The second number is the temperature at which it starts to become ineffective.
I'm not positive on all this though, but it's what first comes to mind. I guess the oil you are using is a heavier one than normal, but I don't think that will be a huge problem. Heck my friend ran gear oil in his engine for a while and it didn't kill it, though I doubt it did the best job.
Look up the manual for your engine. Odds are very good it specs SAE 30 in "normal" temp ranges, and 10W30 for a broader temp range.
