Engine mod questions
Jake.B
California-USA
I have a 5hp briggs and stratton, i plan on getting 9-11 hp out of. i know most of the tricks but i had some questions. First, after removing the govener and buying the correct parts to run safely what pound valvesprings should i buy from the increased RPM? Also where can i get smaller head gaskets? One more thing, if i plan on spending the money for this would it be a good idea to buy TC instead of using a Cent. clutch? I have seen them in photos but to me the TC seem bulky and the kart im building im not sure how much space will be available, and could some one run me by of how they work exactly i know a little about them but not much.
Thanks
FlatFootRacing
Speed Freak
Easley, SC
What Cam are you going to use? that determines what springs! 20lb springs are a good start! A cent. clutch will be ok...depends on what you are doing and how fast you wanna go!
FlatFootRacing
Speed Freak
Easley, SC
A TC uses a Variable Pulley system and a Jackshaft! As the front pulley speeds up it narrows the belt groove pushing the belt higher in the pulley, esentially acting like a larger pulley! as the kart speeds up the rear variable opens allowing the belt to ride lower in the belt groove, acting like a smaller pulley! This allows you to have good take off power, while not sacrificing top end speed! The rear pulley is mounted to a jackshaft which will have a sprocket on the other end to drive the rear wheel Via chain or another belt (most karts use a chain, buggies may use the belt).
Jake.B
California-USA
I dont know if i will change the cam i was thinking just running it at the higher RPM would call for heavier valve springs? Whats your suggestion on the stock cam 18-20 pounds?
