Engine, is this good ?
Think about it. If it has bad/no compression, it will roll over with little or no resistance. If it feels like it gets hard every 2nd crank rotation, it's a good sign. If engine does not rotate at all, you bought a USCG-approved anchor.
r97
Measure twice cut once
Massachusetts, USA
Nope, unfortunately for you that isn't from a NX650 dominator, or one of its little 250 or 125 brothers. (Ignore) Someday I will own a Honda NX, someday.... (Stop ignoring). Your engine looks like one of those 200cc, Lifan (Chines) "vertical" cylinder engines for sale on ebay. For the price, the engine was probably worth it, but I personally wouldn't find it worth while attempting a rebuild. If you want to use it, try to get it running without doing much internally, and use the crap out of it.
HaM551
Perth, Western Australia
thats the plan :D, also it will act as a nice practice engine, but i have noticed markings on the picture so maybe i will be able to get some extra info from them.
Kaptain Krunch
Pro Junk Collector
vermont
Sprocket size, not sure. you'll have to see what the bike used. Probably somewhere around 4:1 ration but thats just a blind guess.
Air filter, uni-pod.
getting it clean? brakleen? rags? depends where its leaking from, and how much. probably not the end of the world.
fowler
Bullsbrook West Aus
Try and find an origonal carb
Or measure the engine intake and then find a carb that will fit
Any 4 stroke carb of similar displacement will work
Look for a bike carb as bike engines rev much higher than industrial engines
